3 Channel Industrial IoT Wireless AC Current Monitor Sensor User Manual
Introducing NCD’s Long Range Industrial IoT Wireless 3 Channel AC Current Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture.  This 3 Channel Industrial IoT Wireless AC Current Monitor Sensor transmitter works together with three split core current sensors (included). It samples current at a high data rate and calculates the RMS Current value and sends a wireless transmission. This process is repeated at user defined timing interval while sleeping in between to minimize power consumption. The sensor comes with three 1.25 meter long split core current sensors which makes installation easy.
This 3 Channel Industrial IoT Wireless AC Current Monitor Sensor is capable of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled as needed. To minimize power consumption, the current sensor sleeps to preserve battery life. Both of these features work together to support multiple application areas in one package.
  • Industrial Grade Wireless 3-Channel Current Monitor
  • AC Current Range 0-100/200/600/1000A RMS Measurement (depending on the chosen probe)
  • Auto Time Delay Based Data Sample Transmission
  • Current Change Detection and Transmission
  • Ideal for 3-Phase Motor Current Monitoring
  • Configurable Current Sensor Calibration Over Wireless
  • Up to 2 Mile Line-of-Sight Range with On-Board Antenna
  • Fully configurable via Node-RED
  • Power-Efficient Sleep Mode, Up to 10 Year Battery Life
    • User Configurable Sleep Duration
Hardware Controls
Power Switch
  • Battery Power
  • External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
  • Configuration Button Pressed and held immediately after reset for
    • < 2 second – device starts normally in RUN Mode
    • 2 to 15 seconds – device goes into Configuration Mode
Click to enlarge
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 28,
    "sensor_data": {
      "channel_1": 5,
      "channel_2": 3,
      "channel_3": 6,
    "sensor_name": "24-Bit 3-Channel Current Monitor",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • channel_1
    • The measured current on Channel 1 in Amps
  • channel_2
    • The measured current on Channel 2 in Amps
  • channel_3
    • The measured current on Channel 3 in Amps
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 28,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 28,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 28,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 28,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 28,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 28,
    "sensor_data": {
      "channel_1": 5,
      "channel_2": 3,
      "channel_3": 6,
    "original": {...},
  "payload": {
      "channel_1": 5,
      "channel_2": 3,
      "channel_3": 6,
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • channel_1
  • channel_2
  • channel_3
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Channel 1 Current Calibration Value
The current calibration value for the first channel.
New calibration value = ((current_read_by_meter/current_read_by_sensor)*
last_stored_calibration_value)*100
Channel 2 Current Calibration Value​
The current calibration value for the second channel.
Channel 3 Current Calibration Value
The current calibration value for the third channel.
Percentage Change Detection - Channel 1
This functionality is disabled by default. If you enable it you can set two parameters:
Percentage Change Threshold – the value in % at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by the set percentage.
Percentage Change Interval – This is the detection time after which the sensor periodically checks for the set percentage change in sensor data from last sample.
So if you set the parameters as per the example the sensor would send a data packet if the current value changes with 14% and 10 seconds have passed after the last data sample.
The above applies for Channel 1
Percentage Change Detection - Channel 2
The above applies for Channel 2
Percentage Change Detection - Channel 3
The above applies for Channel 3
Default Configurations
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay ( Data transmission Interval)600 (DEC) seconds ( minimum 5 sec)
Power+24 dBm
Retries10
Percentage Change Detection - Channel 1Disabled
Percentage Change Detection - Channel 2Disabled
Percentage Change Detection - Channel 3Disabled
Channel 1 Current Calibration Value100Amp -> 87.5
200Amp -> 171.16
600Amp -> 548.06
1000Amp -> 860.02
Channel 2 Current Calibration Value100Amp -> 87.5
200Amp -> 171.16
600Amp -> 548.06
1000Amp -> 860.02
Channel 3 Current Calibration Value100Amp -> 87.5
200Amp -> 171.16
600Amp -> 548.06
1000Amp -> 860.02
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
We have built an example dashboard to display the sensor data from a single Machine Uptime Monitor. You can find it by importing it directly into Node-Red.
  2. Import
  5. Expand Type 28 –
  8. Click on Import
Example Flows
