- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Introducing NCD’s Long Range Industrial IoT Wireless 3 Channel AC Current Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. This 3 Channel Industrial IoT Wireless AC Current Monitor Sensor transmitter works together with three split core current sensors (included). It samples current at a high data rate and calculates the RMS Current value and sends a wireless transmission. This process is repeated at user defined timing interval while sleeping in between to minimize power consumption. The sensor comes with three 1.25 meter long split core current sensors which makes installation easy.
This 3 Channel Industrial IoT Wireless AC Current Monitor Sensor is capable of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled as needed. To minimize power consumption, the current sensor sleeps to preserve battery life. Both of these features work together to support multiple application areas in one package.
- Industrial Grade Wireless 3-Channel Current Monitor
- AC Current Range 0-100/200/600/1000A RMS Measurement (depending on the chosen probe)
- Auto Time Delay Based Data Sample Transmission
- Current Change Detection and Transmission
- Ideal for 3-Phase Motor Current Monitoring
- Up to 2 Mile Line-of-Sight Range with On-Board Antenna
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
The detail of Payload section of packet is shown in table below:
| Frame Field | Offset (Payload section) | Fixed Value (if any) | Description |
| Header | 0 | 0x0F | Header to differentiate various types of packets |
| Node ID | 1 | 0x00 (Factory Default) | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | 01 | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3 | 03 | Battery Voltage = 0.00322*(03*FF+FE) |
| LSB 4 | FE | Battery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V | |
| Packet Counter | 5 | - | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets |
| Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
| LSB 7 | 0x1C | Sensor type 28 | |
| Error/Reserved byte | 8 | 0x00 | For future use |
| Sensor Data | MSB 9/ Data[0] | - | Current data for Sensor 1 |
| 10/ Data[1] | - | Current (unsigned) – mA | |
| 11/ Data[2] | - | Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | |
| Reserved | - | ||
| Sensor Data | MSB 13/ Data[0] | Current data for Sensor 2 | |
| 14/ Data[1] | Current (unsigned) – mA | ||
| 15/ Data[2] | Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | ||
| Reserved | - | ||
| Sensor Data | MSB 17/ Data[0] | Current data for Sensor 3 | |
| 18/ Data[1] | Current (unsigned) – mA | ||
| 19/ Data[2] | Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | ||
| Reserved | - |
Configuration Mode Frame
The following set of commands are an example on how to change some of the parameters that affect the operation of the device (these are parameters that are general in nature, more on a network protocol/device level than device specific). The relate to settings that are independent of the type of probe used. You can find them in Appendix together wit the Device/Application Specific commands.
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05
Complete Payload
Appendix
Configuration Commands
| 15 | Set Change Detection Parameters | 0XF7 | 0x07 | E, PR, T0 MSB, T1, T2 LSB | Enable or disable the percentage change detection. E=1 (Enable), E=0 (Disable) PR is the percentage change detection at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by PR percent T0, T1, T2 - This is the detection time after which the sensor periodically checks for PR percent change in sensor data from last sample |
| 16 | Read Change Detection Parameters | 0XF7 | 0x1A | - | Refer to Command 15 above for the explanation. |
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) | |
| 15 | Set Change Detection Parameters | 1 | 8 | 0xFF (OK) | |
| 16 | Read Change Detection Parameters | 5 | 4 | E, PR, T0, T1, T2 | Detection time = (T0 x 65536) + (T1 x 256) + T2 |
| 17 | Set Calibration Value | 1 | 8 | 0xFF (OK) | |
| 18 | Read Calibration Value | 2 | 7 | C0 MSB, C1 | Calibration Value (float) = ((C0 x 256) + C1) / 100 |
Application Specific Commands
| 1 | Set Calibration Channel 1 | 0xF4 | 0x01 | 0x00 | C0 MSB, C1 | Sets the Current Sensor Calibration in Channel 1 used by the sensor to calculate the current. For example: if you want to set a calibration value of 52.5, write 52.5x100=5250 (decimal) |
| 2 | Get Calibration Channel 1 | 0xF4 | 0x02 | 0x00 | Gets the Current Sensor Calibration used by the sensor to calculate the current. | |
| 3 | Set Calibration Channel 2 | 0xF4 | 0x03 | 0x00 | C0 MSB, C1 | Sets the Current Sensor Calibration in Channel 2 used by the sensor to calculate the current. For example: if you want to set a calibration value of 52.5, write 52.5x100=5250 (decimal) |
| 4 | Get Calibration Channel 2 | 0xF4 | 0x04 | 0x00 | Gets the Current Sensor Calibration used by the sensor to calculate the current. | |
| 5 | Set Calibration Channel 3 | 0xF4 | 0x05 | 0x00 | C0 MSB, C1 | Sets the Current Sensor Calibration in Channel 3 used by the sensor to calculate the current. For example: if you want to set a calibration value of 52.5, write 52.5x100=5250 (decimal) |
| 6 | Get Calibration Channel 3 | 0xF4 | 0x06 | 0x00 | Gets the Current Sensor Calibration used by the sensor to calculate the current. |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
