Feature
Wireless Technology
Battery Life
Specifications | Minimum | Nominal | Maximum | Notes |
Batteries size | 16000mAh | This device has a single D-Cell (LR20) battery | ||
Battery Life 1 TPD | 10 Years | TPD Transmissions per Day | ||
Battery Life 12 TPD | 8 Years | TPD Transmissions per Day | ||
Battery Life 24 TPD | 5 Year | TPD Transmissions per Day | ||
Battery Life 96 TPD | 3 Year | TPD Transmissions per Day |
The Truth About Battery Life
Applications & Use-cases
The Industrial Wireless Thermocouple High Temperature Sensor is capable of monitoring extremely high temperatures in real time. Such a sensor can be useful in various industries and sectors due to its ability to wirelessly transmit critical data, allowing for real time monitoring and prevention of issue (alert notification).
It is ideal for high temperature environments that are not easy to access via humans or cabled sensor due to the increased heat.
Industrial Wireless Thermocouple High Temperature Sensor Applications
Industrial Kiln and Furnace Monitoring
This sensor is ideal for tracking the internal temperature of kilns, furnaces, or ovens used in manufacturing ceramics, glass, or metals. It ensures the temperature remains within required ranges for optimal production quality while reducing the need for manual temperature checks in high-risk environments.
Power Plant Boiler and Steam Pipe Monitoring
Power plants generate steam to drive turbines, requiring precise temperature management in boilers and steam pipes. This sensor can monitor these temperatures wirelessly, ensuring system efficiency, preventing overheating, and alerting operators to deviations.
Food and Beverage Processing
Used in food processing plants to monitor the temperature of high-heat cooking processes like frying, baking, or pasteurization. By maintaining the correct temperature, manufacturers can ensure food safety and quality while avoiding overcooking or burning
Petrochemical and Refinery Process Monitoring
In petrochemical plants, temperature monitoring is critical for processes like cracking and distillation. This sensor can measure extreme temperatures wirelessly, ensuring processes remain within safe limits to avoid equipment damage or hazardous incidents.
Industrial Wireless Thermocouple High Temperature Sensor Use-cases
Foundry and Metal Casting Operations
A metal foundry uses this sensor to monitor molten metal temperatures in casting processes. The sensor tracks temperature in real-time to ensure the metal is heated to the correct range for optimal mold filling and product integrity. If the temperature falls or exceeds the acceptable range, an alert is sent to operators via the wireless system, enabling immediate adjustments and avoiding material wastage or defective casts.
Remote Oil Pipeline Monitoring
In remote oilfields, pipelines carrying crude oil are exposed to varying environmental conditions, potentially causing overheating or cooling that affects viscosity and flow. This sensor, installed along pipelines, continuously monitors temperature at critical points and transmits data wirelessly to a central system. Operators receive alerts when temperatures deviate from safe thresholds, ensuring pipeline integrity and reducing downtime.
Pharmaceutical Sterilization Validation
Pharmaceutical companies use autoclaves to sterilize equipment and products. This sensor monitors the high-temperature steam during the sterilization cycle, ensuring consistent heat levels throughout the process. By wirelessly logging temperature data, the sensor helps ensure regulatory compliance and product safety while reducing manual data collection efforts.
Industrial Equipment Maintenance in Harsh Environments
A manufacturing plant uses this sensor to monitor the temperature of bearings and gears in machinery operating in high-temperature environments. By detecting overheating, the sensor helps predict potential equipment failures, allowing for scheduled maintenance before breakdowns occur. Wireless data transmission ensures monitoring even in hard-to-reach locations.
