2 Channel Industrial IoT Wireless AC Current Monitor Sensor Datasheet
Introducing NCD’s Long Range Industrial IoT Wireless 2 Channel AC Current Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Ā This 2 Channel Industrial IoT Wireless AC Current Monitor Sensor transmitter works together with two split core current sensors (included). It samples current at a high data rate and calculates the RMS Current value and sends a wireless transmission. This process is repeated at user defined timing interval while sleeping in between to minimize power consumption. The sensor comes with two 1.25 meter long split core current sensors which makes installation easy.
This 2 Channel Industrial IoT Wireless AC Current Monitor Sensor is capable of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled as needed. To minimize power consumption, the current sensor sleeps to preserve battery life. Both of these features work together to support multiple application areas in one package.
  • Industrial Grade Wireless 2-Channel Current Monitor
  • AC Current Range 0-100/200/600/1000A RMS Measurement (depending on the chosen probe)
  • Auto Time Delay Based Data Sample Transmission
  • Current Change Detection and Transmission
  • Configurable Current Sensor Calibration Over Wireless
  • Up to 2 Mile Line-of-Sight Range with On-Board Antenna
  • Wireless Mesh Networking using DigiMeshĀ®
  • Fully configurable via Node-RED
  • Power-Efficient Sleep Mode, Up to 10 Year Battery Life
    • User Configurable Sleep Duration
Figure 1: Device Overview
Width3.54"
Length4.52"
Height2.16"
Enclosure RatingIP65, NEMA 1,2,4,4X,12,13, UL-508
Temperature Rating-40° C23° C85° CComponent Rating
Tested Temperature0° C23° C40° CAs Tested by NCD Staff
Probe Temperature-40° C23° C85° CAs Tested by NCD Staff
InputsCurrent
Measured Current Range0 A1000 ADepends on the particular probe chosen
Resolution50 mA500 mADepends on the particular probe chosen (Min measured current 1.5% of FS)
ParameterMinimumNominalMaximumNotes
Trace Width0.007 inch0.012 inch0.25 inchTrace Width depends on the Trace Type
Layer Count2L - RigidTop and Bottom Layer
Material TypeFR-4 TG170FR-4 TG170FR-4 TG180
Surface FinishENIG 2u"
IPC StandardIPC CLASS 2
Finished Copper Foil1.0/1.0 OZ
Finished Thickness0.062 inc
Fine line <4.0/4.0milNo
Blind & Burried ViasNo
Non-Conductive ResinNo
Conductive ResinNo
Figure 3: Mechanical Drawing
RF Module Specifications
Parameter868MHz900MHz2.4GHz
Frequency Band863 MHz to 870 MHz902 to 928 MHzISM 2.4 GHz
Transmitter PowerUp to 13 dBm ERPUp to 24 dBmUp to 8 dBm
Receiver Sensitivity-106 dBm at 80 Kbps-101 dBm at 200 Kbps-103 dBm at 250 Kbps
Range (dense urban)~1000ft~1000ft~300ft
Range (line of sight)~2 miles~2 miles~1 mile
Data Rate80 Kbps200 Kbps250 Kbps
Networking ProtocolDigi XBee® DigiMesh®Digi XBee® DigiMesh®Digi XBee® DigiMesh®
Encryption128-bit AES128-bit AES128-bit
Reliable Packet DeliveryRetries/acknowledgementsRetries/acknowledgementsRetries/acknowledgements
IDsPAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)
CertificationCE/RED, ROHS CompliantFCC (America), IC (Canada), C-Tick (Australia), Anatel (Brazil), IDA (Singapore)FCC (America), IC (Canada), RCM (Australia), Anatel (Brazil), Teleck MIC (Japan), KCC (South Korea)
Probes Specifications
Current Sensor
NCD offers several options for the current clamp for this sensor. Depending on which one you chose, the measurement range will be different, here are you options:
  • 100 amp CT: 50mA resolution ( Min measured current 1.5% of FS)
  • 200 amp CT: 100mA resolution ( Min measured current 1.5% of FS)
  • 600 amp CT: 300mA resolution ( Min measured current 1.5% of FS)
  • 1000 amp CT: 500mA resolution ( Min measured current 1.5% of FS)
Probe Configuration and Wiring
  1. Powered by AA batteries (NCD recommends Energizer L91 batteries)
  2. External power supply (5-12 V DC) Current Requirement 250 mA (optional)
While changing the batteries:
  1. Turn off the sensor
  2. Only use new L91 batteries
  3. Checkout the polarity marking on the battery holder and batteries
  4. Replace all six batteries with new L91 batteries. Do not mix old and new batteries
  5. Batteries should not be replaced in fire-risky areas
  6. Do NOT install rechargeable batteries
Batteries244May be Powered by 2 or 4 AA Batteries
Battery Life 6 TPD (TPD Transmissions per Day)8 YearsBattery estimation is based on a 30 min interval
Battery Life 12 TPD (TPD Transmissions per Day)5 YearsBattery estimation is based on a 30 min interval
Battery Life 24 TPD (TPD Transmissions per Day)3 YearBattery estimation is based on a 30 min interval
Store and Documentation
Head to the NCD store if you want to purchase theĀ 2 Channel Industrial IoT Wireless AC Current Monitor Sensor.
If you already have the device and would like more information into its basic and advanced operations check out theĀ Quick Start GuideĀ andĀ User Manual.
