2 Channel Industrial IoT Long Range Wireless 4-20mA Current Receiver User Manual
Introducing NCD’s Long Range Two Channel Industrial IoT Wireless 4-20mA Current Receiver, boasting up to a 2 Mile range using a wireless mesh networking architecture.  It incorporates a High resolution 2 channel 16-bit ADC that samples 4-20mA analog inputs at user defined intervals and transmits the result to remote modems and gateways.  Between samples, this device enters a ultra-low power sleep mode to minimize power consumption. This Industrial IoT Wireless 4-20mA Current Receiver has an additional feature of detecting change in current every 7 seconds (user configurable) and sending out ADC samples if the change in current on any channel is greater than 10% (user configurable).  Both features work simultaneously to support multiple application areas in one package.
This 2 Channel Industrial IoT Wireless 4-20mA Current Loop Receiver has on board 16V buck boost power supply, thus eliminates requirement of external power supply. This power supply is used to power up the external 4-20mA sensor. This device can be used with any 2 wire 4-20mA sensor/device into a wireless nodes.
This 2 Channel Industrial IoT Wireless 4-20mA Current Loop Receiver is powered by just 6 AA batteries and  a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered. This product has capabilities of supporting 6-32VDC  external power supply (Optional).
  • Industrial Grade 2-Channel 4-20mA Current Loop Receiver
  • Input Range 0-20mA with 15-bit Resolution
  • On Board 16V Supply to Power up the external 4-20mA Devices
  • Supports 2 and 3 Wire Devices
  • Auto ADC Transmission on Analog Voltage Change Detection
  • Converts 4-20mA devices into Wireless Nodes
Hardware Controls
Power Switch
  • Battery Power
  • Off
  • External Power
Click to enlarge
RESET Button
Click to enlarge
CFG Button
Click to enlarge
Hardware Mode Selection
Factory Default/Reset
  • Configuration Button Pressed and held immediately after reset for
    • < 2 second – device starts normally in RUN Mode
    • 2 to 15 seconds – device goes into Configuration Mode
Click to enlarge
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 52,
    "sensor_data": {
      "adc1": 6400,
      "adc2": 3200,
      "mA1": 4.39,
      "mA2": 2.19
    "sensor_name": "16-Bit 2-Channel 4-20mA",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
  • adc1
    • The RAW value from the 16-bit ADC converter on the 1st channel
  • adc1
    • The RAW value from the 16-bit ADC converter on the 2nd channel
  • mA1
    • The value from adc1 converted to a current value in mA. This is the actual measured current.
  • mA2
    • The value from adc2 converted to a current value in mA. This is the actual measured current.
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 52,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 52,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 52,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 52,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 52,
    "nodeId": 0,
    "mode": "FLY",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 52,
    "sensor_data": {
      "adc1": 6400,
      "adc2": 3200,
      "mA1": 4.39,
      "mA2": 2.19
    "original": {...},
  "payload": {
      "adc1": 6400,
      "adc2": 3200,
      "mA1": 4.39,
      "mA2": 2.19
  "_msgid": "48e99332fc104565"
msg.payload Breakdown
  • adc1
  • adc1
  • mA1
  • mA2
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID and Delay
    • Node ID
    • Delay
  • Power
  • Retries
Sensor Boot Time
This value represents the number of seconds to wait after applying power to the sensor before taking a reading. Only recommended for sensors powered by the Wireless Sensor’s power supply.
The device works in such a way that you have 3 calibration points (at 6mA, 12mA, and 18mA).
Each calibration point corresponds with the aforementioned known signal values, which we assign RAW ADC output values to. Each calibration point value can be configure separately, where it is calculated via the formula:
Calibration value = Known signal / RAW ADC * multiplier
For example:
If we apply 6mA and we get a RAW ADC output of 8000 we would have the following calibration value:
Calibration value = (6/8000) * 10^8 = 75000
Low Calibration Point
Default: 68805
Mid Calibration Point
Default: 68724
High Calibration Point
Default: 68714
Auto Check Interval
This command defines how often the sensor checks the current value and performs an auto check for significant changes.
To disable the auto check interval feature make this setting active and use a value of 0.
Auto Check Threshold
The value is entered in percentage. If the percentage change of the measured value since the last transmission is greater than the set value, a new transmission will be initiated.
Example: Threshold set to 20% and last reading was 5. If AutoCheck detects a value below 4 or above 6 a transmission will be sent.
Default Configurations
ParametersDefault Value
Destination Address00 00 FF FF (HEX)
Network ID7F FF (HEX)
Node ID0
Delay600 (DEC) seconds
Power+24 dBm
Retries10
Sensor Boot Time0
Low Calibration Point68805
Med Calibration Point68724
High Calibration Point68714
Serial Connection
  1. Name
  2. Modem Type
  3. Serial Port
  4. Baud Rate
  5. Network ID
    • The default value is 7FFF
TCP Socket Connection
  1. Name
  2. Modem Type
  3. TCP Port
  4. IP Address
  5. Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Press and release the RESET button and then immediately hold the CFG button for > 15 seconds
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
We have built an example dashboard to display the sensor data from a single 2 Channel Industrial IoT Long Range Wireless 4-20mA Current Receiver. You can find it by importing it directly into Node-Red.
  2. Import
  5. Expand Type 52 – 2 Channel 4-20mA Receiver
  8. Click on Import
Example Flows
