Explore the 2 Channel Industrial IoT Long Range Wireless 0-10VDC Receiver Capabilities
Introducing NCD’s Long Range Two Channel Industrial IoT Wireless 0-10V Receiver, boasting up to a 2 Mile range using a wireless mesh networking architecture.  It incorporates a High resolution 2 channel 15-bit ADC that samples 0-10V analog inputs at user defined intervals and transmits the result to remote modems and gateways. Between samples, this device enters a ultra-low power sleep mode to minimize power consumption.
This 2 Channel Industrial IoT Wireless 0-10V Receiver has on board 16V buck boost power supply, thus eliminates requirement of external power supply. This power supply is used to power up the external 0-10V sensor. This device can be used with any 0-10V sensor/device into a wireless nodes.
This 2 Channel Industrial IoT Wireless 0-10V Receiver is powered by just 6 AA batteries and a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered. This product has capabilities of supporting 6-18VDC external power supply (Optional).
- Industrial Grade 2-Channel 0-10V DC Voltage Receiver
- Input Range 0-10VDC with 15-bit Resolution
- On Board 16V Supply to Power up the external Analog Devices
- Converts Voltage Output devices into Wireless Nodes
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Probe Operating Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
RF Module Specifications
Probes Specifications
- External power supply (6-18 V DC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
| Battery Life 1 TPD | 8 Years | TPD Transmissions per Day | ||
| Battery Life 12 TPD | 5 Years | TPD Transmissions per Day | ||
| Battery Life 24 TPD | 3 Year | TPD Transmissions per Day |
Head to the NCD store if you want to purchase the 2 Channel Industrial IoT Long Range Wireless 0-10VDC Receiver.
