2 Channel Industrial IoT Long Range Wireless 0-10VDC Receiver API Overview
Introducing NCD’s Long Range Two Channel Industrial IoT Wireless 0-10V Receiver, boasting up to a 2 Mile range using a wireless mesh networking architecture.  It incorporates a High resolution 2 channel 15-bit ADC that samples 0-10V analog inputs at user defined intervals and transmits the result to remote modems and gateways.  Between samples, this device enters a ultra-low power sleep mode to minimize power consumption.
This 2 Channel Industrial IoT Wireless 0-10V Receiver has on board 16V buck boost power supply, thus eliminates requirement of external power supply. This power supply is used to power up the external 0-10V sensor. This device can be used with any 0-10V sensor/device into a wireless nodes.
This 2 Channel Industrial IoT Wireless 0-10V Receiver is powered by just 6 AA batteries and a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered. This product has capabilities of supporting 6-18VDC  external power supply (Optional).
  • Industrial Grade 2-Channel 0-10V DC Voltage Receiver
  • Input Range 0-10VDC with 15-bit Resolution
  • On Board 16V Supply to Power up the external Analog Devices
  • Converts Voltage Output devices into Wireless Nodes
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Power Up Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 52 55 4E 00 00 00 00 00 00 0BExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7A1Header with Power Up value
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x0B1Checksum
7E 00 1C 90 00 13 A1 00 41 58 1C CB FF FE 00 7A 01 00 00 01 00 00 50 47 4D 00 00 00 00 00 00 1CExample frame
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0x0E1Checksum
0x7E1Delimiter
0x001C2Length
0xFFFE2Reserved
0x001R. Option
0x011Node ID
0x001Separator
0x00012Sensor Type
0x00002Separator
0x0E1Checksum
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the Machine Uptime sensor sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
Figure 4: Communication Procedure - Run Mode
The detail of Payload section of packet is shown in table below:
Frame FieldOffset (Payload section)Fixed Value (if any)Description
Header00x0FHeader to differentiate various types of packets
Node ID10x00 (Factory Default)Node ID to differentiate up to 256 nodes in a network. User configurable values
Firmware201Used to determine firmware version programmed in the device
Battery VoltageMSB 303Battery Voltage = 0.00322*(03*FF+FE)
LSB 4FEBattery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V
Packet Counter5-It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets
Sensor TypeMSB 60x00Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end.
LSB 70x38Sensor type 56
Error/Reserved byte80x00For future use
Sensor 1 Data9/ Data [0]-ADC 1 Counts
10/ Data [1]-ADC 1 Counts = (Data[0] x 256) + Data[1]
Sensor 2 Data11/ Data [0]ADC 2 Counts
12/ Data [1]ADC 2 Counts = (Data[0] x 256) + Data[1]
Configuration Mode Frame
Figure 5: Communication Procedure - Configuration Mode
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
15Set Change Detection Parameters0XF70x07E, PR, T0 MSB, T1, T2 LSBEnable or disable the percentage change detection.
E=1 (Enable), E=0 (Disable)
PR is the percentage change detection at which the sensor will send a packet. The sensor sends a packet when two consecutive readings differ by PR percent
T0, T1, T2 - This is the detection time after which the sensor periodically checks for PR percent change in sensor data from last sample
16Read Change Detection Parameters0XF70x1A-Refer to Command 15 above for the explanation.
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
15Set Change Detection Parameters180xFF (OK)
16Read Change Detection Parameters54E, PR, T0, T1, T2Detection time = (T0 x 65536) + (T1 x 256) + T2
Application Specific Commands
COMMANDCOMMANDSUB COMMANDReserve ByteCOMMAND CODEARGUMENT
Set ADC Calibration Point 10xF40x420x00,0x00,0x2D0x01000109CBSet ADC Calibration Point 1 to 68043
Set ADC Calibration Point 20xF40x420x00,0x00,0x2D0x02000105E3Set ADC Calibration Point 2 to 67043
Set ADC Calibration Point 30xF40x420x00,0x00,0x2D0x03000107E4Set ADC Calibration Point 3 to 67556
Get ADC Calibration Point 10xF40x430x00,0x00,0x2D0x01Get ADC Calibration Point 1
Get ADC Calibration Point 20xF40x430x00,0x00,0x2D0x02Get ADC Calibration Point 2
Get ADC Calibration Point 30xF40x430x00,0x00,0x2D0x03Get ADC Calibration Point 3
Set Auto Check Interval0xF40x46--Defines how often the sensor checks the current value and performs an auto check for significant changes.
To disable the auto check interval feature make this setting active and use a value of 0. - valid range (0 - 65535)
Get Auto Check Interval0xF40x47--Read the Auto Check Interval
Set Auto Check Threshold0xF40x48--Defines the percentage change in the monitored value required to trigger a new transmission. If the change in the value since the last transmission exceeds the specified threshold, a transmission will be sent.
Get Auto Check Threshold0xF40x49--Read the Auto Check Threshold
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
