1 Channel Industrial IoT Long Range Wireless Ultrasound Vibration Sensor Capabilities
The Industrial IoT Ultrasound Vibration Sensor from NCD – a high-performance solution engineered explicitly for industry-leading predictive maintenance applications. Integrated with a wireless mesh networking architecture, it delivers an impressive range of up to 2 miles. The sensor employs a high-precision, dual-channel 15-bit ADC, capturing vibration data at user-specified intervals and wirelessly transmitting the recorded data to remote modems and gateways.
Designed with a focus on energy efficiency, the sensor seamlessly transitions into an ultra-low power sleep mode between data sampling periods. Its integrated 16V buck-boost power supply negates the requirement for an external power source, enhancing its versatility.
Powering the sensor are six AA batteries that, coupled with an operational capacity of up to 100,000 wireless transmissions, afford an estimated battery lifespan of 10 years. This lifespan depends on environmental conditions and the frequency of data transmissions. The sensor also supports optional external power from a 6-18VDC supply for added flexibility.
Its superior range, high precision, extended battery life, cost-effectiveness, and fortified security features position this sensor as an exceptional tool for predictive maintenance tasks in various industrial contexts, exceeding the standards set by traditional devices.
Its main feature include:
- Industrial Grade 1-Channel Ultrasound Vibration Sensor
- Resonant frequency Fres = 37 [kHz] +/- 1 [kHz]
- Measuring range 20 to 100 [dBµVRMS]
- Resolution 0.5 [dB𝜇𝑉RMS]
- Ideal For Motors, Pumps, and Gear Box Predictive Maintenance
| Width | 4.53" | |||
| Length | 3.56" | |||
| Height | 2.25" | |||
| Probe Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Probe connector | M8 |
RF Module Specifications
Probes Specifications
We offer the CONMONSense IP65 SDT 4-20mA Ultrasound Contact Sensor probe (sold separately), which comes pre-provisioned with an M8 connection cable. You only need to plug it into the M8 connector on the sensor.
For details on the SDT probe refer to the link below:
- External power supply (5-18 V DC) Current Requirement 250 mA
While changing the batteries:
- Turn off the sensor
- Only use new L91 batteries
Head to the NCD store if you want to purchase the 1 Channel Industrial IoT Long Range Wireless Ultrasound Vibration Sensor.
