The Industrial IoT Ultrasound Vibration Sensor from NCD – a high-performance solution engineered explicitly for industry-leading predictive maintenance applications. Integrated with a wireless mesh networking architecture, it delivers an impressive range of up to 2 miles. The sensor employs a high-precision, dual-channel 15-bit ADC, capturing vibration data at user-specified intervals and wirelessly transmitting the recorded data to remote modems and gateways.
Designed with a focus on energy efficiency, the sensor seamlessly transitions into an ultra-low power sleep mode between data sampling periods. Its integrated 16V buck-boost power supply negates the requirement for an external power source, enhancing its versatility.
Powering the sensor are six AA batteries that, coupled with an operational capacity of up to 100,000 wireless transmissions, afford an estimated battery lifespan of 10 years. This lifespan depends on environmental conditions and the frequency of data transmissions. The sensor also supports optional external power from a 6-18VDC supply for added flexibility.
Its superior range, high precision, extended battery life, cost-effectiveness, and fortified security features position this sensor as an exceptional tool for predictive maintenance tasks in various industrial contexts, exceeding the standards set by traditional devices.
- Industrial Grade 1-Channel Ultrasound Vibration Sensor
- Resonant frequency Fres = 37 [kHz] +/- 1 [kHz]
- Measuring range 20 to 100 [dBµVRMS]
- Resolution 0.5 [dB𝜇𝑉RMS]
- Ideal For Motors, Pumps, and Gear Box Predictive Maintenance
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Run mode is the default mode of operation of this sensor. In this mode, the device sends periodic packets with the sensor measurement data. During the time it is not sending it enters deep-sleep to conserve power. The sensor’s X-bee module operates in API mode and sends packets to the saved destination address on the network specified by the saved PAN ID. Figure 4 illustrates the API transmission/reception procedure.
The detail of Payload section of packet is shown in table below:
| Frame Field | Offset (Payload section) | Fixed Value (if any) | Description |
| Header | 0 | 0x7F | Header to differentiate various types of packets |
| Node ID | 1 | 0x00 (Factory Default) | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | - | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3 | - | Battery Voltage = ((Battery Voltage MSV x 256) + Battery Voltage LSB) x 0.00322 V |
| LSB 4 | - | ||
| Packet Counter | 5 | - | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets |
| Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end. |
| LSB 7 | 0x58 | Sensor type 88 | |
| Error/Reserved byte | 8 | 0x00 | For future use |
| Sensor Data | 9 / Data[0] | - | ADC 1 Counts |
| 10 / Data[1] | - | Counts = (Data[0] x 256) + Data[1] | |
| 11 / Data[2] | - | mA Value | |
| 12 / Data[3] | - | mA Value = ((Data[2] x 256) + Data[3])/100 | |
| 13 / Data[4] | - | Vibration dB Value | |
| 14 / Data[5] | - | dB Value = ((Data[4] x 256) + Data[5])/100 |
Configuration Mode Frame
The following set of commands are an example on how to change some of the parameters that affect the operation of sensor (these are parameters that are general in nature, more on a network protocol/device level than device specific). The relate to settings that are independent of the type of probe used. You can find them in Appendix together wit the Device/Application Specific commands.
7E 00 17 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F7 02 00 00 00 01 00 00 0A
Payload
A. Node ID
0x01 (Byte 23)
B. New Delay Value
00 00 0A (data bytes 24, 25, and 26)
Delay in seconds = (0x00 x 65536) + (0x00 x 256) + 0x0A = 10 Seconds = 10 Seconds
Read Sleep Duration
Read Sleep Duration Command
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Complete Payload
F7 01 00 00 00
Appendix
Configuration Commands
| 1 | Set ID and Sleep Interval | 0XF7 | 0x02 | NODE ID, D0 MSB,D1, D2 LSB | 0x00,0x00,0x02,0x58 | Sets the Device node ID and Data Transmission Interval. The node id value can go from 0-255 and The Data transmission value can go from 3-0xFFFFFF Seconds |
| 2 | Set Destination Address | 0XF7 | 0x03 | A0 MSB, A1, A2, A3 | 00,00,FF,FF | Sets the Destination Address of the sensor. The sensor will send Run mode Data packets to this Address |
| 3 | Set Power | 0XF7 | 0x04 | Power ( range 1-4) | 0x04 | Sets the RF power of the Sensor Radio |
| 4 | Set PAN ID aka Network ID | 0XF7 | 0x05 | ID0 MSB, ID1 LSB | 0x7FFF | Sets the PAN ID aka Network ID in the sensor. Only sensors, Gateway, and Modes with Same ID can communicate with each other |
| 5 | Set Retries | 0XF7 | 0x06 | Retries | 0x0A | Sets the number of Retries after unsuccessful transmission for the Sensor Radio |
| 6 | Read Sleep Interval | 0XF7 | 0x15 | - | 0x00,0x02,0x58 | Reads the stored Sleep Interval value from the sensor |
| 7 | Read Power | 0XF7 | 0x16 | - | 0x04 | Reads the stored RF Power value from the sensor |
| 8 | Read Retries | 0XF7 | 0x17 | - | 0x0A | Reads the stored Retries value from the sensor |
| 9 | Read Destination Address | 0XF7 | 0x18 | - | 00,00,FF,FF | Reads the stored Destination value from the sensor |
| 10 | Read PAN ID aka Network ID | 0XF7 | 0x19 | - | 0x7FFF | Reads the PAN ID aka Network ID |
| 11 | Read On The Fly (OTN) Control | 0XF7 | 0x31 | - | - | - |
| 12 | Reboot | 0XF7 | 0x40 | - | - | Reboot the sensor |
Command Acknowledgement Data
Each command has its corresponding Acknowledgement with a specific format, size, sections, etc. Use the table below as reference for the parameter values.
| 1 | Set ID and Sleep Interval | 1 | 8 | 0xFF (OK) | |
| 2 | Set Destination Address | 1 | 8 | 0xFF (OK) | |
| 3 | Set Power | 1 | 8 | 0xFF (OK) | |
| 4 | Set PAN ID aka Network ID | 1 | 8 | 0xFF (OK) | |
| 5 | Set Retries | 1 | 8 | 0xFF (OK) | |
| 6 | Read Sleep Interval | 3 | 6 | D0 MSB, D1, D2 LSB | Delay = (D0 x 65536) + (D1 x 256) + D2 |
| 7 | Read Power | 1 | 8 | Power | DEC value |
| 8 | Read Retries | 1 | 8 | Retries | DEC value |
| 9 | Read Destination Address | 4 | 5 | A0 MSB, A1, A2, A3 | |
| 10 | Read PAN ID aka Network ID | 2 | 7 | ID0 MSB, ID1 | |
| 11 | Read On The Fly (OTN) Control | 1 | 8 | OTN Control | |
| 12 | Reboot | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| COMMAND | COMMAND | SUB COMMAND | Reserve Byte | COMMAND CODE | ARGUMENT |
| Enable HPF | 0xF4 | 0x0B | 0x00,0x00,0x17 | 0x00 | Enable HPF |
| Disable HPF | 0xF4 | 0x0B | 0x00,0x00,0x17 | 0x01 | Disable HPF |
| Get HPF | 0xF4 | 0x0C | 0x00,0x00,0x17 | - | Get HPF |
| Set FSR to 0.256 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x05 | Set FSR to 0.256 |
| Set FSR to 0.512 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x04 | Set FSR to 0.512 |
| Set FSR to 1.024 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x03 | Set FSR to 1.024 |
| Set FSR to 2.048 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x02 | Set FSR to 2.048 |
| Set FSR to 4.096 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x01 | Set FSR to 4.096 |
| Set FSR to 6.114 | 0xF4 | 0x40 | 0x00,0x00,0x2D | 0x00 | Set FSR to 6.114 |
| Get FSR Value | 0xF4 | 0x41 | 0x00,0x00,0x2D | - | Get FSR Value |
| Set ADC Calibration Point 1 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x01000109CB | Set ADC Calibration Point 1 to 68043 |
| Set ADC Calibration Point 2 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x02000105E3 | Set ADC Calibration Point 2 to 67043 |
| Set ADC Calibration Point 3 | 0xF4 | 0x42 | 0x00,0x00,0x2D | 0x03000107E4 | Set ADC Calibration Point 3 to 67556 |
| Get ADC Calibration Point 1 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x01 | Get ADC Calibration Point 1 |
| Get ADC Calibration Point 2 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x02 | Get ADC Calibration Point 2 |
| Get ADC Calibration Point 3 | 0xF4 | 0x43 | 0x00,0x00,0x2D | 0x03 | Get ADC Calibration Point 3 |
| Set Boot Time to 10 Seconds | 0xF4 | 0x44 | 0x00,0x00,0x2D | 0x0A | Set Boot Time to 10 Seconds |
| Get Boot Time | 0xF4 | 0x45 | 0x00,0x00,0x2D | - | Get Boot Time |
| Set Multiplication Factor to 73.8 | 0xF4 | 0x46 | 0x00,0x00,0x4B | 0x00001CD4 | Set Multiplication Factor to 73.8 |
| Get Multiplication Factor | 0xF4 | 0x47 | 0x00,0x00,0x4B | - | Get Multiplication Factor |
| Set Constant Value to -53.7 | 0xF4 | 0x48 | 0x00,0x00,0x4B | 0xFFFFEB06 | Set Constant Value to -53.7 |
| Get Constant Value | 0xF4 | 0x49 | 0x00,0x00,0x4B | - | Get Constant Value |
| Generate 2 Pulses | 0xF4 | 0x4A | 0x00,0x00,0x2D | 0x02 | Generate 2 Pulses |
| Generate 3 Pulses | 0xF4 | 0x4A | 0x00,0x00,0x2D | 0x03 | Generate 3 Pulses |
| Set Cycle Duration to 15 Seconds | 0xF4 | 0x4B | 0x00,0x00,0x2D | 0x0F | Set Cycle Duration to 15 Seconds |
| Set Cycle Duration to 32 Seconds | 0xF4 | 0x4B | 0x00,0x00,0x2D | 0x20 | Set Cycle Duration to 32 Seconds |
| Get Pulse Counter | 0xF4 | 0x4C | 0x00,0x00,0x4B | - | Get Pulse Counter |
| Clear Pulse Counter | 0xF4 | 0x4D | 0x00,0x00,0x4B | - | Clear Pulse Counter |
| Start Lube 1 with Timeout 255 Seconds | 0xF4 | 0x4E | 0x00,0x00,0x2D | 0x01FF | Start Lube 1 with Timeout 255 Seconds |
| Start Lube 2 with Timeout 255 Seconds | 0xF4 | 0x4E | 0x00,0x00,0x2D | 0x02FF | Start Lube 2 with Timeout 255 Seconds |
| Extent On The Fly (OTN) Timeout | 0xF4 | 0x50 | 0x00,0x00,0x2D | - | Extent On The Fly (OTN) Timeout |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
0xFF
