Arduino Temperature Sensors
Any Sensor in Seconds
We designed our Arduino Temperature Sensors to be instantly compatible with any platform. For Arduino we have shields that will give a simple plug in to connect to any of our IoT line of boards. All you have to do is add the adapter for your version of Arduino as an add-on and you’re ready to go.
- Arduino Nano and Micro compatible
- Plug and Play connection
- Plug and Play sensor and control expansions
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
Our Arduino Temperature Sensors
We have a full line of Arduino Temperature Sensor options able to cover almost any application. Varying resolution, accuracy, and additional readings like humidity, pressure, or acceleration. Â
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
Local or Embedded
