Arduino 4-20mA current Loop Receiver Shield
Interface 4-20mA sensor With Arduino In Seconds
Arduino is one of the most popular platform among makers and industries. This 4-20mA current loop input receiver board makes possible to connect 4-20mA output sensors like distance sensor, flow meter, current meter, depth sensor with Arduino using this Arduino 4-20mA current Loop receiver shield just by connect a cable.
- Arduino Nano and Micro compatible
- Plug and Play connection
- Plug and Play sensor and control expansions
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
Take a look at our products and see why we’ve been an industry leader for more than 20 years
 If you are looking for Arduino 4-20mA Current loop receiver shield to connect 4-20mA sensor with your Arduino then you are at the right place. ncd.io has a number of 4-20mA current loop receiver board for arduino. These arduino 4-20mA current loop shield has on board 16V power supply which can be used to power up the sensors and read their values. This 4-20mA current receiver shield can be used in industrial automation projects as well. You can pair it with relay board and control devices based on 4-20mA current loop receiver readings. This is an industrial grade high accuracy Arduino 4-20mA current loop receiver shield for arduino which works with all the arduino boards. To make the connections easy you can use this 4-20mA current Loop shield with ncd.io arduino I²C shields.
Why Choose NCD?
How it Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
Local or Embedded?
