Error 404 Digikey Blocked Google Chrome Adding to Shopping Cart
If you engineer products like we do here at ncd.io, you may be frustrated with adding a product to your shopping cart in Google Chrome, only to be confronted with a 404 Error. Luckily, there’s an easy fix that will stop the Digikey Blocked 404 Error. Follow these steps and if you find this helpful, please take a moment to get to know us and look at the products we manufacture for IoT applications. Please note these steps will likely log you out of digikey.com and delete everything in your shopping cart (which is probably inaccessible anyway).
Step 1: Open the Lock
First thing you need to do to stop the DigiKey Blocked 404 error is take a look at your cookies. Google Chrome has a few places where you can examine cookies, but the only place this will be effective is to open the cookies located in the “Lock” icon. This problem is caused by corrupt cookies on your web browser, which are likely due to updates on the DigiKey web site, which are conflicting with older versions of the web site. We will need to take a look at the Cookies by clicking on the “Lock” in Google Chrome. Next, select “Cookies”.
Step 2: Remove digikey.com Cookies
It will be necessary to delete “digikey.com” cookies.
Step 3: Remove www.digikey.com Cookies
It will be necessary to delete “www.digikey.com” cookies as well.
delete cookies digikey.com google chrome error adding to shopping cart[/caption]
Step 4: Click "Done" as shown in the photo above.
Step 5: Test DigiKey.com
You’re done, so now is a good time to test adding products to your DigiKey.com shopping cart. Everything should be working normally now.
