NCD is Currently Experiencing Heavy Order Volumes. Order Processing Time is Now Between 5 and 10 Business Days. We Thank You for Your Patience and Support as We Work to Fulfill Customer Orders as Timely as Possible. Dismiss
  • Industrial Grade Sensor
  • Operating Range 10 to 14000 mbar, -40°C [-40 °F] to +85 °C [185 °F]
  • Configurable Internal Calculation Pressure Resolution 0.2 to 1 mbar
  • Configurable Internal Calculation Temperature Resolution 0.002 to 0.012 °C
  • Accuracy ±20 mbar, ±0.8 °C
  • Absolute Pressure, Relative Pressure and Relative Altitude Change outputs
  • Two modes of Operation
    1. User Configurable Sleep duration
    2. Up to 500,000 Transmissions from 2 AA Batteries
  • Real time battery status
IoT Wireless Temperature Barometric Pressure Sensor
  2. Press the port configure button and select the PORT you identified in step 3. Select baud rate of 9600 and press OK.
ControlAnything.com and ControlEverything Site Migration Notes
©2018 National Control Devices, LLC
ncd.io
Made in the USA
5 Year Warranty
Log in with your credentials
or
Forgot your details?
Create Account
