battery powered iot push notification
IoT Wireless Push Notification Sensor Product Manual
  • Industrial Grade Sensor with µs latency
  • Sleeps when no push input detected
  • 256 Sensor Node per Network
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s IoT Wireless Push Notification Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture.  It transmits highly accurate frames with low latency for every push input or at user-defined intervals.
The range, price, accuracy, battery life and security features of Wireless Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless 24V AC/DC Voltage Detection Sensor, IoT Long range Motion Detection Sensor as well.
M12 Connection
Pin Number Description Cable Wire
1 IO2 Brown
2 3.3V White
3 IO1 Blue
4 COM Black
5 NC Gray
  • Push Notification
  • Wireless input change detection
  • Digital signal monitoring
  • Home Automation
  • Push Notification Type Iot Wireless Sensor (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  • ·         LabVIEW Utility for displaying sensor data (available on our website for free)
  • Run Mode
  • Configuration Mode
(if any)
Header00x7FHeader to differentiate various type of packets
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x02
Reserved80x00
For future use
Sensors Data9/Data[0]Input 1 – High Input: 1, Low Input: 0
Sensors Data10/Data[1]Input 2 – High Input: 1, Low Input: 0
Reserved
110x00
120x00
PIR Wireless Motion Detection Sensor
Sensor Type – 46
(if any)
Firmware2
LSB 4
Packet Counter5
MSB 70x2E
Reserved80x00
For future use
High — Motion was detected
Low — No Motion Detected
Sensors Data10/Data[1]Reserved
Reserved
110x00
120x00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0002 FA
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0002 0000 0004 F5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0002 1234 5678 E4
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0002 02F5
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0002 7CDE 9C
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0002 03F2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0002 E6
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0002 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0002 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0002 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0002 E2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0002 FF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0002 FE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0002 0011 2211 2211 2211 2233 4433 4433 4433 4455
15. Set PIR sensitivity Counter​
The PIR sensor generates a pulse output when motion is detected. To avoid false monition or too frequent detection the Sensitivity can be increased or decreased.
For example is the sensitivity value is 10. In that it will send a notification when the PIR sensor sends 10 pulses to the MCU.
Example Command —
7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 01 00 00 2E 00 00 00 05 CC
F4 01 00 00 23 00 00 00 05
F4 — Command Header
01 — Sub command
00 — Node ID
00,23 – Sensor Type
00,00 — Reserved
00,05 — Sensitivity Counter value.
B. Appendix
  2. Keep only the last 8 bits
