wireless proximity light sensor
Long Range IoT Wireless Proximity Sensor Product Manual
  • Industrial Grade Wireless Proximity and Ambient Light Sensor with 16 bit resolution
  • Proximity distance up to 200mm
  • Proximity Data update rate 32.25 measurements/sec
  • Proximity IR Led current 160mA
  • Ambient Light Range 0.25 to 16k lux
  • Ambient Light Sample Update rate of 3 samples/sec
  • Auto sample transmission on Proximity or Ambient Light change detection periodically (configurable duration in both cases)
  • Configurable Proximity or Ambient Light change detection percentage
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless Proximity Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  It incorporates VCNL 4010 proximity and ambient light sensor and a transceiver that sends data at user defined intervals while sleeping during the time it is not sending data to minimize power consumption. It has an additional feature of detecting change in proximity and ambient light at user defined detection time intervals and sending out samples if the change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user.  Setup of change detection parameters configures these values for both proximity and ambient light. To minimize power consumption, it sleeps during the time it is not checking for change in proximity and ambient light. Both of these features work in parallel to support multiple application areas in one package.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless Proximity Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Wireless Security devices
  • Wireless proximity detection for Racks and Panels
  • Login Automation from a server
  • Wireless optical switch for consumer, computing or industrial devices
  • Wireless dimming control
  • Home Automation
Default Parameters programmed after Factory reset sequence
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
LSB 70x04
Reserved80x00
For future use
Sensors DataMSB 9/ Data[0]
Proximity data
Proximity Counts(unsigned) = (data[0]<<8)+Data[1])
10/ Data[1]
11/ Data[2]
Ambient Light data
Ambient Light Counts(unsigned) = (Data[0]<<8)+Data[1])
          Ambient Light Lux(unsigned) = (Data[0]<<8)+Data[1] x 0.25
LSB 12/ Data[3]
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0009 F3
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0009 0000 0004 EE
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0009 1234 5678 DD
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0009 02EE
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0009 7CDE 95
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0009 03EB
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0009 DF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0009 DE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0009 DD
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0009 DC
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0009 DB
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0009 F8
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0009 F7
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0009 0011 2211 2211 2211 2233 4433 4433 4433 444E
Command For COPY:
7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0009 0014 0000 0ACF
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0009 DA
B. Appendix
  2. Keep only the last 8 bits
