1 channel wireless digital mechanical counter
Long Range IoT Wireless One Channel Counter with Reset Product Manual
  • Industrial Grade Single Channel Counter with Reset Input
  • 32 bit counter
  • Minimum detectable pulse width 100 msec
  • Highly Accurate Pulse Counting
  • Low Latency Transmission
  • Adjustable Counting Threshold for transmission (factory configurable)
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless One Channel Counter with Reset, boasting up to a 28 Mile range using a wireless mesh networking architecture. It incorporates a low latency counter that never misses a pulse even during sleep. The device normally sleeps during no activity. If a pulse arrives at input, it wakes up, counts it and if the number of pulses counted is a multiple of Counting Threshold then it sends a packets with the total number of pulses detected until then. The reset input serves to reset the number of counts to 0 at any time.
Afterwards it goes back to sleep. It also wakes up periodically after user defined delay and sends latest number of pulse counts. Thus with both functions it maximizes power efficiency.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless One Channel Counter with Reset makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Pulse counting
  • Relay on/off counting
  • Home Automation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x23
Reserved80x00
For future use
Sensors Data9/ Data[0]
Counter Counts
Counts = (Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+(Data[3])
10/ Data[1]
11/ Data[2]
12/ Data[3]
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0023 D9
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0023 0000 0004 D4
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0023 1234 5678 C3
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0023 02D4
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0023 7CDE 7B
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0023 03D1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0023 C5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0023 C4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0023 C3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0023 C2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0023 C1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0023 DE
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0023 DD
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0023 0011 2211 2211 2211 2233 4433 4433 4433 4434
B. Appendix
  2. Keep only the last 8 bits
15. Set Counter Threshold
This command can be used to change the counter data transmission threshold.
By default the counter threshold value is 50.
Command — 7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 01 00 00 00 00 00 00 64 9B
The above command will set the counter threshold value to 100.
F4 — Header
01 —  Sub Header
00,00,00 — Reserved
00,00,00,64 — Counter threshold value
Read Threshold Counter
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 02 00 00 00 FE
