wireless analog to digital converter
IoT Wireless Analog to Digital Converter Product Manual
  • Industrial Grade 2 Channel Analog to Digital Converter
  • 10 bit Resolution
  • ±2 LSB Absolute Accuracy
  • Auto ADC sample transmission or on analog voltage change detection periodically (configurable duration in both cases)
  • Configurable Analog voltage change detection percentage
  • 256 Sensor Node per Network
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s IoT Wireless Analog to Digital Converter (ADC), boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture.  It incorporates a 2 channel 10 bit ADC that samples analog inputs at user defined intervals while sleeping during the time it is not sending data to minimize power consumption. It has an additional feature of detecting change in voltage at user defined detection time intervals and sending out ADC samples if the change in voltage on any channel is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change in analog voltage. Both of these features work in parallel to support multiple application areas in one package.
The range, price, accuracy, battery life and security features of IoT Wireless Analog to Digital Converter makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless DC Voltage Monitor(0-10V),IoT Long Range Wireless 0-24VDC Voltage Monitor, and IoT Long Range Wireless 4-20mA Current Receiver as well.
  • Analog Voltage monitoring
  • Analog voltage change Alarm
  • Home Automation
  • ADC type NCD IoT Wireless Sensor (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  • ·         LabVIEW Utility for displaying sensor data (available on our website for free)
Default Parameters programmed after Factory reset sequence
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x03
Reserved80x00
For future use
Sensor Data9/ Data[0]
ADC 1 Counts
          ADC Counts = (Data[0] x 256) + Data[1]
10/ Data[1]
11/ Data[2]
ADC 2 Counts
          ADC Counts = (Data[2] x 256) + Data[3]
12/ Data[3]
Dual Probe Soil Moisture Sensor
Dual Soil Moisture Data Format
(if any)
Header07F
Node ID10x00 Factory DefaultNode ID to differentiate up to 256 nodes in a network. User configurable values
Firmware2
Battery VoltageMSB 3, LSB 4
Use this equation to calculate battery %.
Battery % = 0.537*ADC – 449.9
Packet Counter5It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets.
Sensor TypeMSB 6, LSB 70x44Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
Reserved8
For future use
Sensor Data/ Soil Probe 1 Raw9/Data[0], 10/Data[1]ADC 1 Counts Soil Probe 1
Sensor Data/ Soil Probe 2 Raw11/Data[2], 12/Data[3]
ADC 2 Counts Soil Probe 2
Sensor Data/ Soil Probe 1 VWC13/Data[4], 14/Data[5]VWC1= ((Data[4] x 256) + Data[5])/100.00
Sensor Data/ Soil Probe 2 VWC15/Data[6], 16/Data[7]VWC2= ((Data[6] x 256) + Data[7])/100.00
Soil Moisture Temperature and EC Sensor
Soil Moisture Temperature and EC sensor Data Format
ByteFunctionValueDescription
1Header07F
2Node ID10x00 Factory DefaultNode ID to differentiate up to 256 nodes in a network. User configurable values
3Firmware2
4Battery Voltage MSB
5Battery Voltage LSBMSB 3, LSB 4
6Packet Counter5It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets.
7
8Sensor TypeMSB 6, LSB 70x45Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
9Reserved8
For future use
14Sensor Data/ Soil Moisture9/Data[0], 10/Data[1],11/Data[2], 12/Data[3]Soil Moisture %
Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00
15Sensor Data/ Soil Temperature 13/Data[4], 14/Data[5],15/Data[6], 16/Data[7]Soil Temperature in C
Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00
16Sensor Data/ Soil EC17/Data[8], 18/Data[9],19/Data[10], 20/Data[11]Soil Electrical Conductivity
Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00
17Sensor Data/ Soil Salinity 21/Data[12], 22/Data[13],23/Data[14], 24/Data[15]Soil Salinity
Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00
3 Channel Soil Moisture Temperature and EC Sensor
1Header07F
3Firmware2
7
8Sensor TypeMSB 6, LSB 70x47Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end
9Reserved8
For future use
18Sensor Data/ Soil Moisture 225/Data[0], 26/Data[1],27/Data[2], 28/Data[3]Soil Moisture %
19Sensor Data/ Soil Temperature 29/Data[4], 30/Data[5],31/Data[6], 32/Data[7]Soil Temperature in C
20Sensor Data/ Soil EC31/Data[8], 32/Data[9],33/Data[10], 34/Data[11]Soil Electrical Conductivity
21Sensor Data/ Soil Salinity 35/Data[12], 36/Data[13],37/Data[14], 38/Data[15]Soil Salinity
22Sensor Data/ Soil Moisture 339/Data[0], 40/Data[1],41/Data[2], 42/Data[3]Soil Moisture %
23Sensor Data/ Soil Temperature 43/Data[4], 44/Data[5],45/Data[6], 46/Data[7]Soil Temperature in C
24Sensor Data/ Soil EC47/Data[8], 48/Data[9],49/Data[10], 50/Data[11]Soil Electrical Conductivity
25Sensor Data/ Soil Salinity 51/Data[12], 52/Data[13],53/Data[14], 54/Data[15]Soil Salinity
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0003 F9
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0003 0000 0004 F4
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0003 1234 5678 E3
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0003 02F4
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0003 7CDE 9B
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0003 03F1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0003 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0003 E4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0003 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0003 E2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0003 E1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0003 FE
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0003 FD
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0003 0011 2211 2211 2211 2233 4433 4433 4433 4454
Command For COPY: 7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0003 0014 0000 0AD5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0003 E0
B. Appendix
  2. Keep only the last 8 bits
